Hi everbody
Can you help me to get a perfect fixture voor ayra compar 20 6 ch???
Help me ayra compar 20 fixture Topic is solved
Tommygun112
- FreeStyler Version: 2
- I Use FreeStyler for: None of your damn business!
- FreeStyler Version: 4.1.7
Re: Help me ayra compar 20 fixture
Is this your lighting instrument?
Tommygun112
yes it's the right one
Attached is a 6 channel fixture. You may click on Windows->All to have Freestyler display the helpful programming windows.
There should be 4 custom sliders for the Channel 6 functions (turn the functions off via the standard slider). The manual says there are 15 predefined colours that can be selected by channel 6. The colour selections were not listed so I used a custom slider instead of a colour wheel. If you can provide the colors the fixture can be updated.
Tommygun112
Its perfect but i first choice one colour en after one colour i choice color fading but after the colour fading it not can go back two one colour its keep in colour fading or sound mode?Rod_Horning wrote: 11 Jul 2018, 18:23 Attached is a 6 channel fixture. You may click on Windows->All to have Freestyler display the helpful programming windows.
I apologize if I do not understand your problem correctly.
If you used the custom slider to chose Colour Fading or Sound Control you must use the standard Freestyler slider (which appears in the upper right hand corner of the Freestyler window) to set channel 6 to 0. After you set channel 6 to 0 then the RGB colors should function.
