I have a simple LED cube with 3 channels - Red, Green, Blue and have successfully created a fixture.
I'd like to create a sequence/cue... for the light to "pulse". Say I want it to pulse in red color meaning the fixture is off and as I fire this signal the light starts to turn red, progressively turns brighter before going back to 0 - almost like a sine wave type curve - probably going from 0 to 255 and back to 0.
Along the same lines the default state of the light should be blacked out so only shows a color if triggered.
Can something like this be done with Freestyler or is this material for other software like LightJams etc.?
Pulsating fixture
tfmeier
- FreeStyler Version: 4.01
Re: Pulsating fixture
Just create a 2 step sequence with fade times to match what you would like to see. Please read then wiki on how to make sequences
tfmeier
Thanks. Will try that
