Freestyler App
- FreeStyler Version: 4.01
Freestyler App
The Freestyler app no longer works correctly with the software. Can someone get the developer of the app to fix it so that it works? If not can someone please write another app? I will be happy to purchase the app.
NitroEnter
- FreeStyler Version: 3
Re: Freestyler App
Ios or Android?
Re: Freestyler App
either
Keibir
Re: Freestyler App
I develop the iOS app. What doesnt work? The connection?
Are your smartphone and freestyler in the same network? Does your firewall let it through? Do you use the right ip?
Re: Freestyler App
Sorry, I am speaking of the android version
The app loads up just none of the buttons or cuelists show up and sometime 16 of 32 lists show up
I will purchase the IOs version and see how that works
Re: Freestyler App
Downloaded but cannot get it to connect to Freestyler
Keibir
Re: Freestyler App
okay - so let us find the error.
Which iOS-Version? Device? Freestyler-Version?
What do you type into the ip and port fields? If you use port 3332 - try 3333.
Is there an Error popping up in the top?
- remco_k
- FreeStyler Version: N/A
Re: Freestyler App
Running an Android app on iOS doesn't work, is my guess.
Keibir
- remco_k
Re: Freestyler App
Fair enough.
Re: Freestyler App
Android app does not work correctly on Android device
IOS device now connected and working
Is there a way on IOS app to just have a list of cuelists instead of having to pull them up in a menu?
Keibir
Re: Freestyler App
So you want a Page like the Cues but for the Lists so you can toggle all at once?
I could implement this
Re: Freestyler App
yes please
