Limit to steps in a cue?
- FreeStyler Version: 2.96j
- I Use FreeStyler for: Film
I just ran in to a 15-step limit while making some chases up. Is this a hard limit? How does one do a longer rotating (transparent) sequence?
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
Re: Limit to steps in a cue?
do a search in the forum,
this has been asked by many and there are a lot of responses, but in short you can change the limit in the freestyler.ini file
Hadn't seen anything useful in the first few pages of searching, I guess I wasn't using the right keywords!
Found the value in the INI file and that did the trick! Thanks!
