FIXTURE SAGITTER SLIMBAR 8DL
elsavo
FreeStyler Version: 3.6.4
I Use FreeStyler for: Theater
Post by elsavo »
i guys,
i bought six sagitter slimbar 8dl, i'm trying to build the fixture for freestyler but it's not easy for me..
someone could help me?
thank you so much.
10 Ch (10ch) đź”—
# Type Presets
1 Intensity 000-255 Min Max
2 Strobe 000 Open
001 Slow
255 Fast
3 Chase 000-017 Open
018-035 Auto 1
036-053 Auto 2
054-071 Auto 3
072-089 Auto 4
090-107 Auto 5
108-125 Auto 6
126-143 Auto 7
144-161 Auto 8
162-179 Auto 9
180-197 Auto 10
198-215 Sound 1
216-233 Sound 2
234-255 Sound 3
4 Chase Speed 000-255 Slow Fast
5 Red 000-255 Min Max
6 Green 000-255 Min Max
7 Blue 000-255 Min Max
8 White 000-255 Min Max
9 Amber 000-255 Min Max
10 UV 000-255 Min Max
FreeStyler Version: 4.1.7
Re: FIXTURE SAGITTER SLIMBAR 8DL
Post by Rod_Horning »
Attached is my attempt for the 10 channel fixture. I have also attached the user manual if anyone needs it.
After you select the fixture in Freestyler click on the top menu item Window -> All.
SG SLIMBAR8DL.pdf
(997.28 KiB) Downloaded 8 times
SG_SlimBar8DL_10ch.pff
(33.82 KiB) Downloaded 19 times
elsavo
Post by elsavo »
perfectly working!
thank you so much!
elsavo
Post by elsavo »
perfectly working!
thank you so much!
elsavo
Post by elsavo »
perfectly working!
thank you so much!
