Hello, i have an rgbw wash.(White different channel not mixed)
I want to program in override buttons a strobe (white only) effect.
But when i have Red Colour and want to strobe it strobes Red-White not only White.
How can disable red...and keep only the white?
About RGBW Wash
Motsik
- Twitter: http://twitter.com/#!/motsik
kabak_85
- FreeStyler Version: 3.646
Re: About RGBW Wash
When you create the sequence, you have to move the red, green and blue channel in order to force Freestyler to record those value
In transparent mode, for each step, Freestyler only save the value who was changed (fade mode or Snap mode or value change on channel).
So you can create an white strobe button if you act on all color channel and strobe channel.
Or you can create an strobe who keep the colors from over sequence if you act on strobe/lamp channel only.
I had those two type of strobe override on my list.
Speak English / Parle Français.
