Clay Paky - AledA Wash K20 CC Topic is solved
Taske
Post by Taske »
Hello Freestyler Community.
Is anyone able to do a fixture for the "old" Aleda of Clay Paky? (K20)
I am a bit confused about the RGB-mode with the fixture creator. with "normal" moving lights i didnt had any problems.
Link for the DMX-Channel List is:
https://www.claypaky.it/media/documents ... 016_EN.pdf
The standart-mode (20 channel) would be more then enough for me.
kind regards
Taske
FreeStyler Version: 4.1.7
Re: Clay Paky - AledA Wash K20 CC
Post by Rod_Horning »
Attached is a fairly rudimentary 20 channel fixture definition that should work.
Freestyler directly supports fine (16 bit) Pan and Tilt.
I do not see any direct support of fine control of the RGBW and dimmer channels. You can control these functions via the standard Freestyler sliders.
I did code a couple of macros. Open the macros window to see them.
You should also open the colors window. This will give you a pallet to mix the RGB channels and also show color channel 2 for the Linear CTO
I did not code any macros/gobos/colors for the color or function macro channels. There are so many I wasn't sure the amount of space taken by the windows to display these would be helpful - probably easier to keep a cheat sheet and just use the standard Freestyler sliders.
Hope this helps.
FYI. If I understand the documentation it is possible to control each individual LED. This requires the use of many, many DMX channels. Freestyler support is provided via the RGB segments feature.
Aleda_Wash_K20_20ch.pff
(48.98 KiB) Downloaded 48 times
Taske
Post by Taske »
perfect One!
thank you very much.
the 90 channel mode is not very interesting for us, since you only can control 4 light per universe ;)
is there a tutorial how to use the RGB Segments for rgb-led movinglights? dont want to annoy you for every led-washer i have to test.
thanks alot for the help!
I do not know about a tutorial, there may be one in the WIKI.
When you open the color pallet window for a fixture that has RGB segments defined there are check boxes in the lower left of the window. Each check box controls an RGB set. Checking a box or boxes enables the color mixture pallet to control the selected RGB set(s). Checking a box is somewhat like selecting a fixture.
Hope this helps.
