need fixture - HELP! Topic is solved
jrsampaio
Post by jrsampaio »
Hello!
I bought the WHITE STAR SKY II DMX curtain for stage show from SHOWTEC (iwant@showtec.info), but I don't quit know how to setup this fixture.
The Product guide has the following information:
- 4 DMX channels (2x speed and 2x programs for different lights)
- CH1 ~ 0-20 OFF; 21-223 Strobe from Slow to Fast; 224-255 ON
- CH2 ~ 0-20 OFF; 21-223 Strobe from Slow to Fast; 224-255 ON
- CH3 ~ 0-20 OFF; 21-223 Strobe from Slow to Fast; 224-255 ON
- CH4 ~ 0-20 OFF; 21-223 Strobe from Slow to Fast; 224-255 ON
and
- CH1 = Speed; CH2 = Speed; CH3 = Program; CH4 = Program
With a standard controler each channel (1 - 4) opens a different section of lights (but what about the strobe effect???)
I thank you for all the help you may give...
J Sampaio
P.S. - How can I see the effect in Easyview?
Android Dev (Moderator)
FreeStyler Version: BETA
Re: need fixture - HELP!
Post by Mattotone »
Open fixture creator, select other.
set channels to 4.
create macros for ch1 OFF/SLOW/MED/HIGH/ON
do same for chs 2 3 4
You will have to make/modify some custom bmp images for the macros.
Then you can either use the macros or the side bar sliders.
jrsampaio
Post by jrsampaio »
thanks for your help!
