ADJ Inno pocket Z4
DjAris
FreeStyler Version: 3646
ADJ Inno pocket Z4
Post by DjAris »
Question.Is there NY fixture profile for ADJ Inno pocket Z4?
FreeStyler Version: 4.1.7
Re: ADJ Inno pocket Z4
Post by Rod_Horning »
I did not find an existing fixture. Attached are both the user manual and my attempt at a 22 channel fixture.
The following helpful programming windows are available [top menu item Window -> All]
Beam
Colors
Lamp
Macros
Custom Sliders
Pan Tilt
Note that RGB segments are enabled. In the Colors window CMY-RGB tab check which set of lights (or both) you want the color pallet to control.
Your feedback will be appreciated
ADJ_Inno_Pocket_Z4_22ch.pff
(224.06 KiB) Downloaded 22 times
ADJ_inno_pocket_z4.pdf
(1.87 MiB) Downloaded 19 times
