ADJ Mega Par Profile Plus
dj_facet
This is only my second fixture I've created from scratch, seeing I couldn't find one for the ADJ Mega Par Profile Plus. Included are all the color, gobo and fixture images needed. There are several macros to utilize the three pairs of sixteen each color changes, color fades and sound changes. As well as 64 color macros and custom sliders for strobing effects. I'm sure there may be some improvements that can be made, but it works fine for what I need at the moment. If you need this fixture, I hope this helps you. Enjoy!
Mega Par Profile Plus.pff- v1.0
- (171.41 KiB) Downloaded 237 times
- FreeStyler Version: 4.1.7
Re: ADJ Mega Par Profile Plus
Thank you for sharing.
To save you a little work in the future use the Export feature of the Fixture Creator. This puts everything for a fixture into 1 file. When someone downloads and Imports the fixture all of the colors, gobos, etc. are placed in the proper folders.
dj_facet
Thanks for the tip Rod. I never caught the export option in the menu and was unaware of it. I updated my attachment with the .pff exported from fixture creator. Thanks again for the tip.
