Multiple RGB LED control in one fixture
petervdveen
FreeStyler Version: 3.0.1
Post by petervdveen »
Hi Guys,
I´m currently working on a fixture for the ROBE LEDWash 300.
Now this fixture has three rings of LEDs which are individually changeable. So basically I need three RGB color settings in one and also one override to control them all.
Is there any way within Freestyler to add multiple RGB channels?
To clarify (example, not the real channels for this fixture):
Channels | Color
1|R
2|G
3|B
4|R
5|G
6|B
7|R
8|G
9|B
So channel 1, 4 and 7 combined makes the wole fixture red.
Thanks for your help!
FreeStyler Version: 4.1.7
Re: Multiple RGB LED control in one fixture
Post by Rod_Horning »
In the fixture creator click on Enable CMY / RGB and click on RGB segments.
I think this is what you need.
petervdveen
Fantastic, thanks a lot.
Sorry for not figgering it out myself ;-)
No problem. It took me quite some time to understand that feature.
perac1989
Post by perac1989 »
i have multichip led par 54x3W, led par with windmill effect
I have tried to make profile but withouth succes...
can somebody help
there is a link
https://www.dhgate.com/product/2ps-lot- ... 3772881980
I did not find a user manual. Without a description of the channel usage for the mode you want to use, creating a fixture profile is not possible.
