Hey guys, so im using dmx512 interface with 8 RGB LED strips, is there a way to have seperate color windows open for each fixture?
https://gyazo.com/63f1462fc3b134302ca74bc058c57c5a
so underneaf each fixture a color window is shown
TMProjection
- FreeStyler Version: 3.4.6
- FreeStyler Version: 4.01
Re: seperate color windows
No that is not possible at this time. You can select all of the fixtures and get 1 color window that controls all but there is no way to have a color window open for every fixture at the same time.
The software is not designed to be run on "on the fly". The software is designed to create scenes or sequences and stack them for use in various ways. Meaning you should create scenes that do the color patterns you want and save them to buttons or cues for easy repeat use.
You may want to look into using the "DMX400" part of freestyler to control your led pars or strips, it can give you great diversity in your show with very little setup.
Good luck
Good luck
TMProjection
thank you very much for responding, ill be honest this is only for a home project and im experimenting for myself, i been researching into various programs but ive had most success with freestyler at the moment
by any chance do you know of any programs that could have multiple windows open with color selector for each fixture?
opened up dmx400, will have to flick through some tutorials, thank you
I personally do not know of any software that will do what you are wanting (does not mean that it does not exist)
- remco_k
- FreeStyler Version: N/A
Just another thought: just make presets(=sequences) of each color for each fixture you use. Gonna be some work at first. But then:
Put them in Override buttons, or better: in the Cue window. Enable multiple cue's to be run the same time in FreeStyler setup and, if you need quick access, configure shortcut keys on your keyboard to the sequences or override buttons.
OR
Make presets(=sequences) of colors in all fixtures you use.
Put them in Override buttons, or better: in the Cue window. Disable multiple cue's to be run the same time so that if a new sequence is started, the other one stops.
If you need quick access, configure shortcut keys on your keyboard to the sequences or override buttons.
OR
TMProjection
thanks so much for the suggestion, im still a very very new beginner in DMX stuff, will have to look into override, just learnt how to use sequences the other day
thanks dude
thanks dude
Overrides are just another way to run sequences but can only run 1 step sequence also known as a scene
