Showtec spectral 800 Tour Topic is solved
ljauric
Post by ljauric »
Can someone help me with this fixture please...
10 channel dmx mode
Thxs Auric
FreeStyler Version: 4.1.7
Re: Showtec spectral 800 Tour
Post by Rod_Horning »
Is this your instrument?
43500_MANUAL_GB_V1.pdf
(2.27 MiB) Downloaded 37 times
ljauric
Post by ljauric »
Yes it is
Attached is my attempt for the 10 channel configuration
After you add the fixture to Freestyler, select it and click the top menu item Window -> All
This will open 3 helpful programming windows:
Colors (note there are 2 tabs; one for the RGB pallet and one for the color macros)
Lamp
Macros (the first 21 macros [in black] control channel 7, the next five macros [Dim] control channel 9 and the last 21 macros control channel 10.
Showtec_Spectral_M800_Tour_10ch.pff
(120.95 KiB) Downloaded 41 times
ljauric
Post by ljauric »
Thxs! Test it tomorrow!
