First have you tried? Log in to Search the Forum for help! Learn more about using FreeStyler at the FreeStyler WIKI HERE
Please do NOT post bugs here! If you spot a potential Bug please report it HEREfirst then you can chat about it with other users in the appropriate section.
Firstly, What are you trying to do?
DMX Merge?
What interface are you using?
The combination of the DMX controller you are trying to use and freeestyler may not work.
Judging by the back panel pic I just saw I don't think it will unless you are doing a dmx merge in which case you still need an interface for Freestyler.
I think you have to have two separate devices one for recieving the dmx and one for sending the dmx. Devices that have both I think can only work on one mode in or out so you need two devices
