uDMX & refresh rate problems
senzacija
FreeStyler Version: 3.6.4
Post by senzacija »
Hi all... I'm having problem with my uDMX interface. Everything is explained here: viewtopic.php?t=7103,
and here is the video from the thread: https://drive.google.com/file/d/0B_18qy ... tsOWM/view
I saw that the solution is increasing refresh rate to 100, however it seems I can't increase it more that 50 fps..
I've tried different laptops, different uDMX interfaces, disconnecting some of my fixtures and so forth.. nothing helps. This used to work flawlessly few years ago
Aevarex
FreeStyler Version: 3.4.6
I Use FreeStyler for: Band
Re: uDMX & refresh rate problems
Post by Aevarex »
I had an issue and increasing the refresh rate to 100 fixed it.
A short time later I updated freestyler to the latest version and now the refresh only goes to 50, had to reinstall the older version to get the 100 refresh rate back!
Try an earlier version of freestyler, V 3.4.6 is what I'm using still.
FreeStyler Version: 4.1.7
Post by Rod_Horning »
If this is still a problem please submit a change request here:
https://www.freestylersupport.com/bugs
