Hi All,
Any help would be much appreciated please. Is it possible to map a control to Midi device to adjust fade times outside of the sequence, so for example a sequence with a slow fade time can be set to a fast fade time with the a slider control? I don't think it's possible but might as well ask.
Thank you.
Fade time adjust outside of sequence?
Benfleet
- FreeStyler Version: X2
- FreeStyler Version: 4.01
Re: Fade time adjust outside of sequence?
There is a speed slider in the cue window for each cue running and also a master speed. All of them can be accessed by midi control
