Hi
i have one problem, i have the show programmed in Cue buttons, the problem is that everytime i turn off the cue button, one LED stays ON, showing light...
its strange because it seems randomly, when i change to other pc or select other cues, it remains ON with other colors.
when i turn Blackout ON, it works well, only cues have that problem.
seems that its a bug? =(
Cue Button Shutter LED Light Problem Issue Turned ON
k__x
- FreeStyler Version: 3.3.4
- FreeStyler Version: 4.01
Re: Cue Button Shutter LED Light Problem Issue Turned ON
Everything should go to previous values when turning cues off. Ideally you should have a cue thats "all off".
k__x
in some Cues, when i unselect the button, its one robot that remain with the shutter ON , other buttons are other..it dont make any sense...
how can i change the OFF values of the Cues buttons when they are unselected?
put them all to 0 ?
put them all to 0 ?
