I have some problems with my martin mac 250 in combination with the mac 500, bacause the mac250 can do 540 degrees in pan direction and the mac 500 only 440 degrees. So if I want them all (I have 2 and 2) to do the same move, its pretty hard to program.
So my idea was to give the mac250 new max and min values for pan with the fixture creator. But its not possible, because you can only enter how much degrees the fixture does, not the dmx values...
I tried it also with the correction tool. The problem here is, that this value is only added to the actual value. So the fixtures are in sync at the start position, but they get unsync all the more you move them.
Is there anyone who had the same problem and solved it or anyone with an idea?
Would be very nice
Btw, same problem with tilt, but here the difference between the fixtures isn´t so big as it is at the pan.
Greets!
