Hi everybody
i need a help
i was setting the submaster and suddenly the submaster window didn't appear, i've tried reopen the window and nothing, the window don't want to appear... someone help meeee !!!
Urgent! Submaster Window
hevybolter
- FreeStyler Version: x2
- FreeStyler Version: 4.1.7
Re: Urgent! Submaster Window
I have never had this occur.
First, back up Freestyler.
Next, try rebooting Windows.
If that does not work then reinstall Freestyler.
Please open a bug report and describe what you were doing and what happened and the results.
- FreeStyler Version: 4.01
go into setup, preferences, extra settings and select to reset all windows
hevybolter
The option reset all windows works... the submaster window appear.
Thanks Partyman.
