Reset fixtures question
Caloute
FreeStyler Version: 3.645
Post by Caloute »
Hi All,
So I play a bit with the lights using submasters and the buttons, but I exited them with a few stuff on, like shutters and color, so they are still stack with this parameters now, what are the step needed to reset them (apart from exiting the program which works). Thank you
Caloute
FreeStyler Version: 4.01
Re: Reset fixtures question
Post by Partyman »
"release all" and "release all buttons" should do what you are wanting. You may need to set up keyboard shortcuts
