Hello,
I just buy 2 new moving heads (lightmaxx vega spot 90)
They are just great. (fix gobo's, rotation gobo's, auto focus, shutter, prism, prism roatation ...)
I created a profile for freestyler and it is running well.
There is 1 thing that i do not found how to fix, maybe someone can help me please ...
In the moving head there are 2 gobowheel and also a colourwheel.
When I use the first gobowheel with fix gobo's, the focus is on a position and the gobo's are sharp. So OK.
But when i use the rotation gobo's, they are not sharp, so i have to change the focus and then it's ok.
And now the question:
Is there a way in freestyler that when you select a gobo from gobo wheel 1 or 2 that, the focus is positionated automatically so that i always have sharp gobo's ...
Hope somebody can help me ...
Focus in moving head with 2 gobo wheels
Boone
- FreeStyler Version: 2.96g
- FreeStyler Version: 4.01
Re: Focus in moving head with 2 gobo wheels
Thats the way fixtures are designed not the way freesyler works. Every fixture I have ever worked with had the two gobo wheels with different focus points, not sure why.
malykazio
- FreeStyler Version: 3.5.9
Just make macros for each gobo, there you can set not only gobo value, but every setting you wish.
