i've downloaded a Chinese fixtures pack from the site.
Inside i've found a folder named 18led par china, i've tried this one and partial work for me.
the Red, Green and blue light turn on and the master work, the only two thing that don't work is the strobe effect and the Change Color.
viewtopic.php?t=4528
this is the link of the topic i've downloaded the chinese pack
Thanks.
Chinease 18Led PAR Fixture
hevybolter
- FreeStyler Version: x2
- FreeStyler Version: 4.1.7
Re: Chinease 18Led PAR Fixture
Are you certain your instrument has a strobe and color change feature? If not then the fixture will not respond to the DMX values sent to either of those 2 channels.
Can you provide either a link to the user manual or perhaps pictures of each page of the user manual?
hevybolter
I do not have the user manual, I bought the package and inside there were only the lights, no manual, if I change the mode, the strobe mode is there, so I guess I can set it via dmx
Are you willing to spend some time experimenting?
If so create a test location in Freestyler and download and import to the test location the attached 32 channel generic fixture. Make sure the fixture's starting address matches the physical configuration of your instrument.
Set all of the channels to around 70%.
Now vary the channels one by one and observe the effect on your instrument.
Hopefully you will find the channel that controls the strobe and perhaps other features. Be aware that many multi-function lights require that 2, perhaps 3, channels work together for certain functions.
If you can determine what channels do what a fixture definition can be created.
Good luck!!
Good luck!!
Generic 32 Channel.pff- (4.7 KiB) Downloaded 38 times
hevybolter
I tried with freestyler to implement the attachment and as in the case of the set I used, only the first 4 channels work: the first is the master, the second the red, the third the green and the fourth is blue. I made a video while changing the modes of light
https://youtu.be/tGdFBkNJ4Vw
Thanks a lot
Thanks a lot
hevybolter
INCREDIBLE, I found the solution during the video ... the first two modes of the lights are A001 and D001, I always used the D001 thinking the D was for DMX, instead changing the mode in A001 came out the hidden features
Thanks for the help
Thanks for the help
