cheap chinese mini par
djniuss
FreeStyler Version: x2
Post by djniuss »
Hi i have a cheap chinese led mini par
it sais 8 ch ...
the probleme is every time i put the dmx cable in it it goes into sound activated mode.... if i remove it close the light (off)
it does this in all the cheanel i tried.
faulty device or im too noob for this.
FreeStyler Version: 4.1.7
Re: cheap chinese mini par
Post by Rod_Horning »
Without more detail it is difficult to determine the problem. One possibility it may be that you have the physical instrument configured for DMX and the starting channel address that is configured is such that when you plug in the cable the instrument is reacting to a DMX signal from an active controller such as Freestyler.
djniuss
Post by djniuss »
thanks
i cannot give more detail. after trying different software it always do the same thing . even with the dmx testin softwar. i have a diy usb to dmx wich the dmx tester tested succefully. as sson as the ligt start blinkin on the dongle the light start reacting to sound in every software i tried i in. it does this with the tester also.
