I have a little setup working fine but theres a problem using override buttons.
i have movements (ok)
Strobes, blackout (ok)
but with chases the button only plays the first step.
i have a color chase button win 5 steps, running in the cuelist it works fine, but in the override buttons it only stays in the first step.
i need to use only override buttons to make the software easy to use fot the non lighman DJ.
how is the right way to play buttons with more than 1 step chases??? why i can not use them in the override buttons window?
