barra led beam 8x8 Topic is solved
visho
barra led beam 8x8
Post by visho »
hola amigos,
necesito con urgencia el fixture para esta luminaria.
es de 11 canales solo color blanco
1: dimer
2: luz 1
3: luz 2
4: luz 3
5: luz 4
6: luz 5
7: luz 6
8: luz 7
9: luz 8
10: strobo
11: pan (265º)
es esta luminaria
https://www.youtube.com/watch?v=u9ddSzLgZPc
si me pueden ayudar se los agradecería mucho.
saludos cordiales. :fs:
FreeStyler Version: 4.1.7
Re: barra led beam 8x8
Post by Rod_Horning »
Please post a link to the user manual. The channel usage in your post does not seem to match what I found from the link to the manufacture on the Youtube page.
visho
Post by visho »
hello friend ... what happens is that I can not find the manual of the luminaire since the light is a wild pro brand, the functions of the channels I removed from the light myself since I currently control it with a dmx analog console and now I want to control it with freestyler.
those are the channels and their functions, I just do not know how to create the fixture.
Attached is my attempt.
Click on the top menu item Window -> All to see the following helpful programming windows:
Lamp
Pan/Tilt
Bara LED Beam 8x8.pff
