Ayra TDC Hybrid Beam Fixture Request Topic is solved
stijnb1234
Post by stijnb1234 »
Hi Everyone,
I'm in search on a fixture profile for the Ayra TDC Hybrid Beam.
I've also attached the user manual.
Bye!
Stijn
:fs:
ayra_tdc_hybrid_beam_user_manual_v2.pdf
(345.86 KiB) Downloaded 37 times
FreeStyler Version: 4.1.7
Re: Ayra TDC Hybrid Beam Fixture Request
Post by Rod_Horning »
Thank you for attaching the user manual.
Attached is my attempt at a fixture definition.
The color window is available with this fixture definition.
The manual has no information about gobos except that channel 1 controls one and channel 2 controls the other.
If you can post DMX values (and shapes) I will update the fixture so that the gobo windows will display.
Ayra_TDC Hybrid Beam.pff
(41.2 KiB) Downloaded 38 times
