Antrolite AL-MNWSH 86 LED Topic is solved
tesicmex
Post by tesicmex »
Hello, I need fixture file for light ANTROLITE model AL-MNWSH, this light have 86 leds (30pcs red, 28pcs green and 28pcs blue), 4 channels, pan 270 degree, tilt 360 degree, strobe speed ajustable.
please helpme!!!!
https://www.chilangoeshop.com/tienda/ca ... ed-ra.html
FreeStyler Version: 4.1.7
Re: Antrolite AL-MNWSH 86 LED
Post by Rod_Horning »
I was unsuccessful in locating a user manual for your AL-MNWSH. This instrument has several functions yet only uses 4 DMX channels (according to the web page for your link). This is unusual - RGB requires 3 channels if each color is adjustable, pan and tilt normally require 2 channels (often 4), strobe is sometimes controlled by the same channel as the dimming function but usually has its own channel.
If you can please either provide a link to the user manual or upload either a PDF of the manual or pictures of the pages of the manual.
Attached is a very basic 4 channel fixture. The channels are simply labeled channel 1, channel 2, channel 3, channel 4. If you can not find a user manual experiment with your light, using this basic fixture, to determine the function of each channel and the DMX values (or range) of each function of the channel. If you post the results of your experiment I will update the fixture.
Antrolite ALMNWSH 86 LED MH.pff
(20.72 KiB) Downloaded 24 times
