FUN GENERATION LED POT 12x1W QCL RGB WW Topic is solved
xDEMIANx
Post by xDEMIANx »
Inspired by the awesome works of Rod_Horning regarding the Fun Generation product family, here's the .pff file for the QCL RGB WW variant of the LED POT.
This is the 8-channels configuration.
This is my very first attempt to do my own fixture configuration, so thank you in advance for tolerating possible mistakes. It works fine for the basic functions I needed from the fixture. Hope this helps some freestyler fellows out there, too!
This is the link for the free online manual: https://images.static-thomann.de/pics/a ... online.pdf
FunGeneration_RGBWW.pff
8-channel configuration
(109.52 KiB) Downloaded 77 times
FreeStyler Version: 4.1.7
Re: FUN GENERATION LED POT 12x1W QCL RGB WW
Post by Rod_Horning »
:) Thank you
xDEMIANx
Post by xDEMIANx »
Thank you too for unveiling the mysteries of DMX! My light show works fine because of you!
