Create standalone show Topic is solved
mousegr8house
Post by mousegr8house »
Hi guys and girls.
I have a question.
Is it possible to create a standalone show that will run all night without the need of an light engineer?
I like to create a huge pre programmed show.
In trying different ways in freestyler but i cannot seem to build a 1 hour lightshow that will loop for 8 hours.
I have not looked at the go monkey app for freestyler yet will try that asap.
Maybe someone on here have a brilliant idea.
I used freestyler for fun at my house and private partys.
Used to play for my work on avolites and jands hog dmx controllers few years ago.
Now i organize house partys , and the venue has gotten everything in sound active mode.
So i convinced the owner to go the dmx route .
Now i have 8 scanners 2 rgb lasers and 4 movingheads in the venue.
For my own night dmx controlling is not an issue.
But the lights now look so good more people want to organize partys.
The owner knows i used to be live light engineer.
But i dont have time on a thursday night to make lightshows for a party and on friday morning go to normal daytime job.
I hope i can accomplish this With freestyler as i am familiar With that.
Otherwise i need to look into other dmx software.
Id rather make a donation to freestyler instead of buying something Else which offcourse has a learning curve again.
Best regards
Maurice
FreeStyler Version: 4.01
Re: Create standalone show
Post by Partyman »
I am pretty sure you can do it with go monkey. Should be able to build a 1 hr cuelist then load multiple copies in Go Monkey list and set it auto. You may be able to do it with straight cues but i dont know if limitations will stop you.
mousegr8house
Thanks for your reply , partyman.
Go monkey it is then.
