Cue Botton/ Sequence Help
Djfattony
FreeStyler Version: 3.6.4
Post by Djfattony »
Ok I'm stumped on this one. Been loving freestyer as a Dj it has been great and has most of the options I need more so then alot of big name softwares.. But this one has me stumped so hoping you can help. As a dj I need sound control and single button loads. Im using a Apc Mini for midi control. Now the problem I have seems simple. I have build Sequences is some 15 to 20 steps that I load into the cue list and assign them to a Cuelist button. But when I hit play it loads every single sequence in the cue at once. Is there a way to start with say the first in the list and have it look though them all and repeat. Thanks for great software and great help.
FreeStyler Version: 4.1.7
Re: Cue Botton/ Sequence Help
Post by Rod_Horning »
Try this:
In the Cue Window click on the gear icon in the left hand side of the menu bar
Make sure Loop All Sequences and Always start with 1st Scene are checked.
Djfattony
Post by Djfattony »
I have that set but when I hit the cue button it still loads every sequence at once. until they all run.. then they will run as they should. the result is a few seconds of crazy light show. I am running the latest verison of freestyler could be a bug. must most liikly something I have wrong someplace
Djfattony
Post by Djfattony »
Djfattony
Post by Djfattony »
Something else to try. In the Cue window click on the gear icon on the RIGHT hand side. Click on Load Cue Only.
Djfattony
Post by Djfattony »
Well that sort of work.. Now it will only load the first one playing but will not auto start it when I press the Cue Button. Even tried the start with first scene toggle. It eather one loads the whole page of sequences or 2. Load them but does not play them.
Djfattony
Post by Djfattony »
Ok I think I can make it work that way.. once I start the cue it will continue even until the next cue is started.. I did lose the ability to click it again which stopped everything but I can always use the blackout or shutter button for that also.
Loading the Cue does load all the sequences. What I don't understand is, since you have Loop All Sequences and Always start with 1st Scene checked, why all the sequences run at the same time. I am also running the latest version of Freestyler. I do not experience this issue.
I think I am still missing something. If I stumble onto it I will update this thread.
rsumrall
FreeStyler Version: 3.5.3
I Use FreeStyler for: Band
Post by rsumrall »
Having the exact same problem. I think it is a bug.
FreeStyler Version: 4.01
Post by Partyman »
In the cue window top left is gear icon, make sure that "Cue Multiselect is always enabled" is NOT checked
