MIDI to DMX Utility Topic is solved
Codeweasel
MIDI to DMX Utility
Dear All,
As mentioned elsewhere in this forum, I have been writing a Windows utility that will allow the direct control of DMX channels from MIDI notes. This extends the idea of the 24 MIDI to DMX channels feature inside of Freestyler and should allow the user to assign any of 512 DMX channels to any of 127 MIDI notes.
Please note and apologies - One big shortcoming so far is that I only have a 'uDMX' interface, so this application is currently limited to working with that until or unless someone can help me out with others (software/API/drivers or indeed hardware)
I attach a .zip file below with the setup file and a user guide inside.
Feel free to let me know any feedback
Graham (Codeweasel)
Graham (Codeweasel)
MIDI-2-DMX.zip- (685.97 KiB) Downloaded 221 times
nightflowers
Re: MIDI to DMX Utility
This is exactly what I was looking for, unfortunately I have an Enttec USB Pro interface.
You can find the API for this interface here : https://dol2kh495zr52.cloudfront.net/pd ... i_spec.pdf
+ demo files : http://www.enttec.com/download/pro_example_v2.zip
The Windows drivers : http://www.ftdichip.com/Drivers/CDM/CDM20828_Setup.exe
and if you need anything else there's a download section on the product page : https://www.enttec.com/eu/products/cont ... x-usb-pro/
Can you look into it please ?
t3kboi
Would you be willing to share source for this?
I am trying to build a theatrical interface that uses the uDMX, but I am not much of a programmer. Being able to see code behind the working example would be very helpful.
fusionman
Great. I'll try it!
I'm a .net developer and seems that you are using .net framework.
Maybe I can help you to improve this application
Codeweasel
Sorry All,
I totally forgot I had uploaded this and have moved on to using Freestyler in a little more depth for my band's needs.
I did once look into the Enttec drivers stuff, but not having an interface to try, it was all a bit confusing for me.
I will however, happily share the source code for the utility. I will post it when I find it (on my home machine).
Graham.
Graham.
Codeweasel
Found it...
Do with it as you please, but be aware of my disclaimer that I accept no responsibility for this code or anything anyone comes up with as a result of editing it.
Cheers
Graham
Cheers
Graham
MIDI2DMX.zip- (968.48 KiB) Downloaded 172 times
fusionman
Thank you Codeweasel. I'm giving a look to your code.
I develop in c#...your is VB code but that's okay
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
May i suggest you use the sendmessage api to control the output directly though freestyler, you can have direct acces to all 1024 channels if required, this will make your application interface netural and still alow FS to control other channels not being consumed by your midi app.
oldschool87
Hi Guys,
have you svilupped this utility for work with enttec pro MKII?
thanks a lot! i would control old halo par64 with 48ch dimmer pack via midi buttons/slider....
