I play in a band and I'm trying to migrate our lighting control from an old physical control unit to FreeStyler running on a Windows tablet. I'm programming the different scenes we use to run off cue list buttons and everything's working fine, apart from one problem. I normally wear glasses for reading & close-up work, but I prefer not to wear them while playing, which means I can't read my labels on the cue list buttons.
Does anyone know if it's possible to change the text size on the cue list buttons?
Cue List Button Text Size Topic is solved
- FreeStyler Version: 4.01
Re: Cue List Button Text Size
It may be possible by editing the Freestyler script but I am not aware of any way.
doctorzorro
- I Use FreeStyler for: Eurovision
I searched through all files in the freestyler folder that are readable with notepad, .ini, .dat, .fsd etc...
I could not find any reference or entry for the fonts used for the buttons or their size/color.
See my post on this forum, I would be interested to know where these parameters reside as well.
Let's hope someone has a deeper knowledge of Freestylers innards and is willing to share these insights.
Red lights are bad for ya, mmkay?
Codeweasel
I believe Freestyler is written in VB6, which means that, unless Raph has specifically programmed to allow text size changes on buttons and other interface elements, its not something you are going to find in any .ini or config file. Font types and sizes are drawn internally from Windows, so what you *could* do would be to go to Control Panel and make changes to the current 'Theme' and/or set the overall text size to 125% or 150%, but that will enlarge everything, not just the FS buttons. Other than that, I'm afraid you are stuffed
- UniCav
- FreeStyler Version: 3.5.2
The way I've handled this was to find the images folder that has all the buttons in it and make a backup copy, then I used an image resize utility to enlarge the button images until I found what worked for my layout. I even edited a few to add my own text. Once you get it where you like it make a copy of the folder to put back whenever the program is updated. I do wish the devs would add something where you could pick the font size or change the button sizes because you really can't see squat with the default text sizes on anything on a tablet or laptop with 1980 screen res
mike_s
Thanks for the suggestion, Codeweasel. The highest I can set the custom display scaling to while being able to fit all the cuelist buttons on the screen is 140%. Unfortunately the button labels are still too small for me to read without glasses.Codeweasel wrote: 19 Feb 2018, 16:06 I believe Freestyler is written in VB6, which means that, unless Raph has specifically programmed to allow text size changes on buttons and other interface elements, its not something you are going to find in any .ini or config file. Font types and sizes are drawn internally from Windows, so what you *could* do would be to go to Control Panel and make changes to the current 'Theme' and/or set the overall text size to 125% or 150%, but that will enlarge everything, not just the FS buttons. Other than that, I'm afraid you are stuffed![]()
mike_s
UniCav, I've had a look around for the folder containing the buttons, but without success. Can you provide any further information on where this is located, please?UniCav wrote: 22 Feb 2018, 15:49 The way I've handled this was to find the images folder that has all the buttons in it and make a backup copy, then I used an image resize utility to enlarge the button images until I found what worked for my layout. I even edited a few to add my own text. Once you get it where you like it make a copy of the folder to put back whenever the program is updated. I do wish the devs would add something where you could pick the font size or change the button sizes because you really can't see squat with the default text sizes on anything on a tablet or laptop with 1980 screen res
- UniCav
I think it's TouchUI Images
