Fixture for Fun Generation LED Pot Strobe 100 Please ? Topic is solved
tozepratas
Post by tozepratas »
Hello , cau anyone get me fixture for this littlle strobe led please
https://www.thomann.de/pt/fun_generatio ... N_383840_3
6.2 Operating mode ‘DMX’
This setting is only relevant if the device is controlled via a DMX controller.
1. Press [Mode] repeatedly until the display shows ‘d.xxx’ .
2. Use [Up] and [Down] to assign a DMX address in the range from ‘d.001’ … ‘d.512’ to the
device and confirm with [Setup].
3. Use [Up] and [Down] to select the desired DMX mode:
Mode Display Highest possible DMX address
1-channel ‘1-ch’ 512
3-channel ‘3-ch’ 510
4. Confirm with [Setup].
Channel Value Function
1 0 … 255 Dimmer (0 % … 100 %)
Functions in 3-channel operation
2 Operating mode
0 No function
1 … 127 Programme speed (0 % … 100 %)
128 … 255 Sensitivity sound control (0 % … 100 %)
3 Stroboscope effect
0 … 1 No function
2 … 255 Strobe frequency (0 % … 100 %)
FreeStyler Version: 4.1.7
Re: Fixture for Fun Generation LED Pot Strobe 100 Please ?
Post by Rod_Horning »
Attached is my attempt at a fixture for the 3 channel configuration.
Helpful programming windows Lamp and Custom Sliders are available.
Fun_Generation_Pot_Strobe_100_3ch.pff
(23.39 KiB) Downloaded 35 times
tozepratas
My friend thank you for your help
Many thanks
