Kam Gobo Tracer Topic is solved
souldude
Kam Gobo Tracer
Post by souldude »
Hi
Very new to using Freestyler . manage to get some other moving heads working but these Gobotracer from Kam are a bit harder and can't get working
Has anybody got a profile, Had a browse through forum but can't see any profile for them
I have the Pdf Manual if its possible
Many Thanks
Kam GoboTracer manual 01-06-16.pdf
(932.59 KiB) Downloaded 30 times
FreeStyler Version: 4.1.7
Re: Kam Gobo Tracer
Post by Rod_Horning »
Attached is my attempt. Thank you for including the link to the manual.
The instrument has a color wheel and a gobo wheel.
The manual does not have information as to what DMX value produces what color.
The manual does have pictures of the gobos but, like the color, does not have information as to what DMX value shows which gobo.
If you can supply the color and gobo values the fixture can be updated so that the Color and Gobo windows can be produced. This will assist in programming.
Any feedback will be appreciated.
Kam_GoboTracer_11ch.pff
(47.88 KiB) Downloaded 28 times
souldude
Re: Kam Gobo Tracer
Post by souldude »
Thank you for that. this is the problem i was having as no other information on the gobos . i have tried my best to find but since Kam went bust there is very little info available now .
Re: Kam Gobo Tracer
Can you slowly slide the standard sliders and make notes?
I've run into this lack of documentation often - very frustrating.
BTW if you click on Window > All in the top menu of Freestyler several helpful programming windows will open.
souldude
Re: Kam Gobo Tracer
Post by souldude »
yeh i will try and get the gobos n colours
souldude
Re: Kam Gobo Tracer
Post by souldude »
hope this is correct .
GOBO TRACER CONFIG.docx
(132.47 KiB) Downloaded 25 times
Re: Kam Gobo Tracer
Thanks for the additional information
Based on your information I have updated the fixture
If you find anything incorrect or any additional information let me know.
(125.52 KiB) Downloaded 29 times
souldude
Re: Kam Gobo Tracer
Post by souldude »
Thank you . will give it a try and let you know
souldude
Re: Kam Gobo Tracer
Post by souldude »
Hi.
tried the profile and i think things working wrongly .
gobo seems to change colour and rotate
dimmer changes colour and rotates
Re: Kam Gobo Tracer
My apologies. I had the color channel incorrect.
Attached is an updated fixture.
Please try it and let me know how it works.
souldude
Re: Kam Gobo Tracer
Post by souldude »
ok thankyou .
just been playing and managed to get 9 channels working on the basic colours .
will try yours and report back
