React to sound turns off in cues
debtman3535
FreeStyler Version: 3.5.5
Twitter: none
Post by debtman3535 »
In the cue window parameters, "react to sound" is enabled. When I load a new submaster into the cue, "react to sound" becomes disabled for almost all of cues.
How do I keep "react to sound" in the cues enabled?
Just updated to 3.6.45. Thanks.
FreeStyler Version: 4.01
Re: React to sound turns off in cues
Post by Partyman »
You must select the sound to light THEN save the cue, you can hit "quick save"
debtman3535
Twitter: none
Thanks.
I use submasters, not cues directly. I have 5 subs for my moving heads for example. They are all linked. If I change the color using one of my color subs, it switches react to sound off in the cue for all of the subs that were linked as well as other cues for other fixtures.
The only way to use react to sound is in the cues? I never had the cue window open as it always seemed to work fine. I opened it for the first time in a year because the react to sound wasn't working after installing the update.
Post by Partyman »
Not sure what to tell you, I dont use submasters.
BillsGate
FreeStyler Version: 4.x
Post by BillsGate »
Looks like your experiencing this bug: https://www.freestylersupport.com/bugs/view.php?id=1375
