Showtec Phantom 65 Fixture File Wanted
Uriahdemon
FreeStyler Version: 3.5.5
I Use FreeStyler for: Band
Post by Uriahdemon »
Hi Folks,
Does anyone have a Showtec Phantom 65 fixture file they are willing to share please.....??
Thanks in advance
FreeStyler Version: 4.1.7
Re: Showtec Phantom 65 Fixture File Wanted
Post by Rod_Horning »
Attached is my attempt. Please provide any helpful feedback.
The following windows are available to assist with the programming:
Beam
Gobos
Macros
Colors
Lamp
Pan / Tilt
Custom Sliders
SHOWTEC_Phantom_65_13ch.pff
(196.08 KiB) Downloaded 81 times
ShowtecPhantom65.pdf
(2.8 MiB) Downloaded 48 times
Uriahdemon
Thanks RH, I will give this a go this evening and get back to you. You would not happen to have an SSL file for Easy View 3D please.....??
I'm sorry, I do not. I have never used Easy View.
geo_liviu_13
FreeStyler Version: 3.5.0
Post by geo_liviu_13 »
Hello ! Please help me. The fixture Phantom 65 led doesn't work on my freestyler. the error is: "Path not found... Showtec Phantom 65_gobo1.bmp"
I do not know why the gobos were not placed correctly when you unpacked the fixture.
Attached is a zip file with the gobo .bmp images.
Unzip the file. The gobo .bmp images must be placed in this path:
Freestyler\Gobos\Showtec\Phantom_65
Phantom_65.zip
(12.89 KiB) Downloaded 52 times
geo_liviu_13
Thank you ! :D
djflockeHB
Post by djflockeHB »
Hello,
i have problem width this Fixture. All work fine but i have only Strobo Light. When i open the shutter i cant take normal light. Can somebody Helb me. Sorry for my bad english.
doohit
Post by doohit »
djflockeHB wrote: 15 Nov 2018, 21:15 Hello,
Same problem here. The Shutter/Dimmer is always off. Output-Source shows the right value at the Shutter/Dimmer Channel but the MovingHead can only the Strobe.
Thanks for Help!
Post by Jan_K »
The data sheet is a bit unclear on the strobe channel. "Open / Closed"
Try this one.
Showtec_Phantom_65_V01_13ch.pff
(197.67 KiB) Downloaded 52 times
