How to work with scenes in freestyler
dennisgamalej
Has mastered Fixture Creator
FreeStyler Version: 2
Post by dennisgamalej »
hello everyone. At school we are going to have a concert and i have to do the lights. So i make scenes i put every scene in a one cuelist. But if i make more quelists and i am now in cuelist one playing a scene and i press cuelist 2 and play there a scene than the scene keeps playing in cuelist 1 . So 2 scenes are playing now but from different cuelists. Can i somewhere select that when i go to an another cuelist and play there a scene that in an other cuelists the scenes are going off and just the scene in which quelist i am is playing? Thank you)))
FreeStyler Version: 4.1.7
Re: How to work with scenes in freestyler
Post by Rod_Horning »
In the CUE list, at the top, are two gear icons. Click on the gear icon on the right hand side and click on Disable previous cue list first. This may do what you are asking.
dennisgamalej
One more qustion is there a fader with which i can made fade from one scene to another?
Sometimes i have a problem when i save a scene i play the scene sometimes its okey but sometimes freestyler turn on also another lights......
