[Question] Does Freestyler work with Martin Universal USB-DMX 2?
Barabba
Post by Barabba »
Hi mates!
I have an old version of lightjokey 2.95.1 and I'm experiencing troubles with 16 bit pan/offset on fixtures. On LJ DMX output panel it looks it works correctly, when the LSB from a 16 bit offset increments a carry goes correctly to MSB and 0 to LSB, as it should be, but in reality the MSB is affected when the LSB value overcomes only 192 (if I remember right). I guess it's a bug of the program, or it can be inside the fixture firmware, or maybe the USB to DMX adapter. I would like to test the adapter with another software, but I'm not sure Freestyler supports this adapter. What do you think? ON Win7-64 it appears like: Jungo - R&D International BVBA - Martin Universal USB-DMX 2
If not, Can you suggest any other way to write directly a value into DMX adress? That can be enough for me to debug the problem
THank you a lot for help!
Return to “DMX Interfaces”
