Kam Gobostar Topic is solved
adamsnowball
Kam Gobostar
Post by adamsnowball »
please could someone do a gobostar fixture profile for me?
Download manual here https://www.dropbox.com/s/u0p8g0sugwu17 ... 9.pdf?dl=0
Many Thanks,
Adam
www.facebook.com/snowballentertainments
FreeStyler Version: 4.1.7
Re: Kam Gobostar
Post by Rod_Horning »
Attached is my attempt at a fixture for your Kam Gobostar
After you import the fixture and add it to the Freestyler workspace, select the fixture and click on the top menu item Window -> All. The following windows should appear:
Colors
Lamp
Macros
Custom Sliders
Kam_Gobostar.pff
(49.41 KiB) Downloaded 6 times
adamsnowball
Re: Kam Gobostar
Thank You for your speedy work! Will try to check it soon
