Equinox Fusion Spot Max mkii Topic is solved
adamsnowball
Post by adamsnowball »
https://prolight.co.uk/product/fusion-spot-max
New to the world of Moving Heads, and have not touched freestyler in years as it was a bit too complicated for me for the fixtures I had before, however if someone could kindly do me a profile I would gladly take up using this software again alongside Virtual DJ. I can't find a manual to view online as all the links just send you to a page to download the pdf, however all the necessary links, gobo and colour wheels can be found on the link above
Hope to hear a response,
Thanks,
Adam
www.facebook.com/snowballentertainments
FreeStyler Version: 4.1.7
Re: Equinox Fusion Spot Max mkii
Post by Rod_Horning »
I think I posted a fixture for this instrument previously (for another user). I did not have the colors and gobos at the time. Attached is an updated fixture (thank you for the manual link).
After you import the fixture and add it to the Freestyler workspace, click on the fixture to select it. This will open these additional helpful programming windows:
Colors
Lamp
Macros
custom sliders
Feedback will be appreciated.
Equinox_Fusion_Spot_10chan.pff
(108.98 KiB) Downloaded 51 times
