Hi Guys . Can you help me with fixture for Lightmax Shaft 5R (17 ch.) ? I have attach the user manual .
Thanks .
Need Fixture for Lightmax Shaft 5R Topic is solved
Dj Belly
- FreeStyler Version: 4.1.7
Re: Need Fixture for Lightmax Shaft 5R
Thank you for attaching the user manual. This fixture has many functions.
My attempt at a Freestyler fixture is attached. After you import it and add the fixture to the Freestyler workspace, select it and click on the top menu item Window -> All. This will open several windows in addition to the standard Freestyler sliders that may help you with your programming. The windows are:
Please provide feedback. Include any suggestions for improvements.
- Beam
Colors
Gobos
Macros
Lamp
Custom Sliders
Pan / Tilt
