Schalter S-049
Andres9898
FreeStyler Version: 1.2
Schalter S-049
Post by Andres9898 »
hi!
I Need fixture Schalter S-049. I can't set up
FreeStyler Version: 4.1.7
Re: Schalter S-049
Post by Rod_Horning »
I was unable to locate a user manual. Please either upload the user manual to this thread or post a link.
Andres9898
Re: Schalter S-049
I need Fixture Schalter S-049, i know the user manual is unable but not has other option?
Re: Schalter S-049
I have looked again for DMX channel information. I did not find any information. If you are willing to experiment perhaps you can find enough information to enable the development of a fixture.
I can post a very generic fixture. You will need to try many combinations of channels to determine the function of each channel. There should be 3 to 5 color channels, perhaps and overall dimmer channel, probably a strobe channel and many some pre-programmed chases.
Please post whether you want to continue with your quest or not.
