30watt Mini Led spot movinghead Topic is solved
barto446
Post by barto446 »
Hello all.
I bought a lamp from Alie.
https://www.aliexpress.com/item/2016-Ne ... type = 600
Now I try to make a 11 channel fixture but not everything works ok.
Would anyone be able to see where I am at fault now? because I do not see it anymore.
The only description I have in the appendix. I followed the forum tutorial and that took a lot of time haha, but in part it works. but not yet complete, hopefully someone can help me to get out the mistake i made
at page 2 of the pdf are the 11 channel settings
FreeStyler Version: 4.1.7
Re: 30watt Mini Led spot movinghead
Post by Rod_Horning »
Your color wheel (channel 5) does not appear to be correct. The Rainbow effect begins at the DMX value of 140. Your color wheel has a fixed color at value 143 and a fixed color at value 154. Your documentation did not include the values for colors so I can not tell you if the rest of the color wheel is correct or not.
I recommend you code a value of 0 for Strobe Off (channel 7)
Does channel 6 control your gobos. Do you have the correct patterns and values?
Please indicate in more detail what is not working and perhaps we can provide more help.
IMPORTANT. Did you use the control panel on the physical instrument to set 11 channel mode. If the physical instrument is set to 9 channel mode the Freestyler fixture will not control your light as you expect. For example, in 9 channel mode channel 3 controls color and channel 4 controls spot (gobo?). In 11 channel mode channel 3 controls Vertical operation and channel 4 controls Vertical Trimming.
barto446
Post by barto446 »
Thank you for the fast replay!
I just modyfi with your recommended code and its al little bit better. The colours are not the same as i program. I set the head at 11 channel, even with the freestyler. I dont have the correct gobos and colour. I am in controle of the pan and tilt now.
The manual i uploaded is everything i got.
I seen this lack of documentation quite often from Aliexpress.
Yes, BOTH the instrument AND the Freestyler fixture must be either 9 channel or 11 channel.
Your instrument does not provide individual control of the RGB or CYM lights, it has predefined colors (which could be because the instrument only has white LEDs and uses a color wheel with gels. The only control you have over color is which one of the predefined colors the instrument displays.
What you can do is use the standard Freestyler slider and move the slider for channel 5 from left to right making a note of the DMX value as each new color is shown. Then edit your fixture so that the color wheel matches these values.
When I click on your aliexpress.com link the web page has pictures of several gobos. If these are correct for your instrument you can use the Windows 10 snipping tool to create a jpeg image of each gobo. Use PAINT to resize the image to 30 by 30 pixels and save the image to the Freestyler/Gobos directory as a BMP. After you have created all of the images then use the channel 6 slider to determine the DMX value for each gobo. Next, edit your fixture, inserting the DMX values and the image associated with that value. If the web page does not show the correct gobo then you could use the Misc_01, Misc_02, etc. GIFs instead.
I hope this helps.
barto446
Post by barto446 »
Hello. Thanx for the help. I managed a little bit. Not everything works perfect,but i am still working on it. The main settings are ok wright now so i can play with it. :) thnks for your support and my bad english haha.
Your English is much better than my ability to speak your language! ;)
