Suddenly big problems with the cue buttons
hahatoni
FreeStyler Version: 3.6.3
I Use FreeStyler for: Band
Post by hahatoni »
Hi!
I am a new user of FreeStyler. The last days I programmed my sequences and put it in the cue list and created a button for each.
To this day it worked properly. I clicked a button, it got blue and the sequence began to run. But now I can't click any button. Nothing happens. Also the play-button (on the left side) doesn't change from stop to play.If I click manually it switches to play, but if I stop it, the lights run along.
I control FreeStyler via a Musicsoftware with Midi NoteOn / Off commands. Also this doesn't work anymore. I didn't change anything at the system.
I run a fresh installed Windows 10. I also deinstalled FreeStyler and reinstalled. It's always the same Problem!
Has anyone a idea? Thank you very much!
FreeStyler Version: 4.01
Re: Suddenly big problems with the cue buttons
Post by Partyman »
Do you have manual control over fixtures? Is USB dongle being recognized and functioning?
No versions have changed and seldom does any software make changes on its own. I would assume it is a driver issue which changed with a windows update. That is why I ask if the USB dongle is working as it should be.
