Hi dear,
i hawe problem with pan tilt fixtures. 1. few scenes are recorded 2. reversed pan and tilt are recorded and normally selected 3. the scenes are played but when pan and tilt are not selected with check marks play function doesn't work as recorded under 2.
Are we doing something wrong or is it program bug?
Regards!
Freestyler pan tilt bug
Đido Mova
- FreeStyler Version: x2
- buttza
- FreeStyler Version: 3.6.4
Re: Freestyler pan tilt bug
Make sure your fixture doesn't have P&T inversion on the actual fixture.
You may need to reset it and start from scratch.
Also make sure that you didn't add P&T inversion for that scene only. Inverted P&T should only be used on initial setup and not during scene / Sequence programming.
Hope that helps.
Hope that helps.
Đido Mova
Thank you, it be good to freestyler crew make this in new wersion.
