Restore values when sequence stops Topic is solved
pakamon57
Hi everybody, I have a big Problem, I've created a sequence with 6 par 56 spots lighting one after the other, it worked fine, I've already activated the restore values button and everything was working well till today ! I don't know why but when I press the play button again to stop the sequence, the restore values function doesn't work... Any Idea ?
pakamon57
Re: Restore values when sequence stops
Hi again, Problem solved ! It wasn't one ! When the fixtures are connected the restore values button works and they stop lighting ... It's only the little color line from each PAR Icon on the PC screen staying active ...
