SGM Galileo IV Topic is solved
Haris_82
SGM Galileo IV
I just create a fixure for this profile. Everything is working well but the problem start with automatic shape. If i choose one color and one gobo and start automatic shape at one moment it turn white and than goes again as selected. Could be a problem with locate and default state?
video pff file chb file
Galleo IV.rar- (962 Bytes) Downloaded 24 times
- FreeStyler Version: 4.1.7
Re: SGM Galileo IV
Please use the Fixture Creator to Export your fixture to a file (the file extension will be .pff) and upload this file (do not compress). The fixture file itself often contains pointers to other files and thus may not work on other people's computers.
Re: SGM Galileo IV
Thank you for uploading the .pff file.
Your video does show the issue.
Another request. Please upload the Sequence file as an RAR or ZIP file that demonstrates the problem.
Haris_82
Re: SGM Galileo IV
I also upload the chb file in rar. So this happend also when i move pan and tilt without using shape.
I have tried to make a fixure in Martin Lightjockey and Dmx Creator with same value and same channel and everything is working well. Only with Freestyler i have this strange problem.
- FreeStyler Version: Beta
Re: SGM Galileo IV
Hej.
When you operate the fixture manually is it then also failing or is it only when you run a sequence.
If it is only when you run a sequence then it is there you need to search eventually by single stepping it.
Haris_82
Re: SGM Galileo IV
When i change colors,gobos,dimmer,focus,iris everything is ok but when i start use pan and tilt something strange happend. I check value channel and they are ok. Pan,tilt,pan fine and tilt fine are on channel 5,6 17,18.
Re: SGM Galileo IV
Have you tried to use the sliders in right side of FS.
You can try them one by one and see which one makes the fixture fail.
Also eventually open the output monitor window to see the what values are changed.
(If it is fast enough to catch it).
Haris_82
Re: SGM Galileo IV
I write it in previous post. When move Pan and Tilt change colors and gobos is some position. We also remove off the head of scanner and tried move pan and tilt. Same happend. I also create same profile without colors, tilt and same happend.
Re: SGM Galileo IV
Yes I read that but there may be a difference if you use the pan / tilt panel or the slider in right side of freestyler.
There may be an error in FreeStyler somewhere and you may need to make a new fixture from scratch adding one functionality at the time to debug.
Also there could be an other thing. FreeStyler may be to fast updating the data.
You can eventually try to change the update rate for interface. It is the same place where you select the interface.
But I don't think that is the problem.
Haris_82
Re: SGM Galileo IV
I tried to change rate. But nothing happend. The problem is somewhere in FS. I will try to fix it.
Re: SGM Galileo IV
Please report your findings in the bug tracker.
