Fixture Showtec Shark Wash One Topic is solved
DimiTheo
Post by DimiTheo »
Hello.
Need fixture for showtec shark wash one
Thank you :fs:
FreeStyler Version: 4.1.7
Re: Fixture Showtec Shark Wash One
Post by Rod_Horning »
Give this a try. Your feedback will be appreciated.
After you import and add the fixture to Freestyler, select it.
After you select it click on the top menu item Window -> All
This will display the following additional Freestyler programming windows (you might need to move them around in order to see all of them):
Beam (zoom)
Pan Tilt
Lamp
Macros
Colors
Custom Sliders
NOTE: This fixture is for the 15 channel configuration. Also attached is the user manual
Showtec_Shark_Wash_one.pdf
(2.16 MiB) Downloaded 56 times
Showtec_Shark_Wash_One_15ch.pff
(85.71 KiB) Downloaded 70 times
DimiTheo
Post by DimiTheo »
Thank you..
Nice fixture but the macros didn't work..
All the others is ok
Thank you.
Have to ask this question first. For the macros to work (they control channel 15), according to the user manual, channel 6 must have a value between 1 and 255 AND channel 13 must have a value between 11 and 255. Was this the case when the macros did not work?
Channel 6 is the overall dimmer channel and Channel 13 is the White intensity. Perhaps I should add these 2 channels to the macro, say at 50%?
