ID writer needed?
tfmeier
ID writer needed?
Post by tfmeier »
I bought a few LED cubes that can be controlled via DMX. I got the fixture done via FC (basic RGB) but can't seem to have control over individual cubes - they all change together. There's no dip switch anywhere and they all respond to ch1-3.
Found this term "ID writer" which seems to suggest you can set an address wirelessly.
What's this ID writer and do I need to get one or is there a software solution I could use to set these addresses?
Sent from my HTC 2PS6200 using Tapatalk
FreeStyler Version: 4.1.7
Re: ID writer needed?
Post by Rod_Horning »
Cube brand and fixture name?
Please upload or provide a link to the user manual.
Also, where did you come across the term "ID writer"? Please provide a link if you can.
