help me create scenes
washtecnic
FreeStyler Version: 3.4.6
Post by washtecnic »
Hello,
I am willing to pay for anyone help me create scenes
we have a series of 28 par lights already configured using freestyler but we are now able nor we know how to do it
we are willign to pay for anyone create the scenes for us
please contact us and i will let you knwo what we would like you tell us how much and hopefully we can do it
thanks
FreeStyler Version: 4.1.6
Re: help me create scenes
Post by Rod_Horning »
Are these par lights the ones you mentioned in your earlier posts?
Please export the fixture definition(s) and attach the export file to this discussion
What are the addresses of the lights?
Please describe the sequences you would like, including timing.
washtecnic
yes they are same par lights I mentioned
how do I export the ficture definition ? what is the fixture file extension?
will it help if I send you the few scenes I already have in the freestyler and the you just modify them ?
in total they are 27 par lights
addresses of each? how can I check it?
if you tell me file extensions to copy inside from my freestyler I can send them to you
so maybe its easier for you to check what I already have in my freestyler and its easier to move on from there
please let me know file you need so I send them to you
thanks
mario
washtecnic
please find attached some fixtures and some chases I already have in my freestyler
what we mainly need is some more new chases
please tell me if you need some other info
I tried to attach fxt and chb files and it says invalid extension
if you give me your email I can send them to you by email
I sent you an email.
To post a fixture file you need to create an export fixture file which is done in the Fixture Creator.
Sequences can be attached if you first place them in a ZIP file.
email will be fine
